- Jul 4, 2012
- 801
- Vinyl
- CircuPool RJ-60 Plus
Something seems suspicious.
Back in May my brand new Dolphin E10 quit after maybe 4 uses. (Thread here: Dolphin E10 new, suddenly won't start)
It was repaired under warranty by a local service (suggested by Dolphin). He told me it was a bad cable, so replaced it.
It worked well for about a month (again 4-5 uses) and then just died again, exact same symptoms as previous - power supply light would come on, but the unit wouldn't move. Called Dolphin and asked if they would just replace it given that it has broken twice now in 10 uses. They had me send it in to them for evaluation. Came back to me a week or so later with a work order that basically said they tested it and nothing was wrong other than the float was in the wrong position. It works fine now (at least for the 3 times I have run it since) but I have a hard time believing that nothing was wrong, but can't really prove anything.
I do not recall the cable having this bulge or splice near the plug but I can't say that for certain. When I check google images I see some cables with and some without this bulge. Anyone have thoughts or insight as to whether the cable is the stock or has been repaired?
My concern is that I have a lemon and I just want an accurate record of its repair history. I emailed Dolphin for a follow up and they just reiterated that they tested it and nothing was wrong, so they sent it back.
