Does shock affect cya testing?
mrdorkdar
87
Lake Forest, CA
Basically I’ll just ask it like this….if I added a couple bags of shock and brushed the bottom of the pool, then tested my cya numbers (because I forgot to do it first) and the test showed my cya at like 150, could that be because I shocked / brushed the pool? I did used to use the stabilized picks so it is possible the cya could be that high but I didn’t know if it could be because I just shocked / brushed the pool which kinda clouded the water up a bit.
i don’t know how it could be that high. I maybe used 10-15 pucks. Before that I was using liquid chlorine without sunblock.
Wow, I did not realize that. How the F do most people not have cya skyrocketing when I feel like most people use powdered shock or pucks?!
We avoid solid forms of chlorination. We encourage the use of saltwater chlorine generators (SWG) and liquid chlorine.
What are your plans? You're going to need to drain a substantial amount of water to get CYA in check. Let us know how we can help.
Reactions: Donldson
