RobbieH said:
I changed my sand last year, only because my filter failed and I wanted to replace everything at once. The filter and sand were installed in 1989, the previous owner left receipts. The filter still worked perfectly fine until the laterals cracked. That's 22 years of service on one filter and sand installation on a large pool.
YEEEAAAHHH!! That's totally awesome!! No water quality difference in the old one (filter+new sand) vs. the new one, I presume?
Swampwoman said:
Okay, so even before I write to the, this is what their FAQ says in a couple of references:
Hayward FAQ said:
Why is the filter continuing to run at high pressure even after backwashing?
Make sure you are following the instructions in your Hayward owner’s manual. The sand bed may be clogged with mineral deposits or other material that will not backwash away. Some calcium based chlorines and other alternative sanitizers could cause a build-up in your sand bed. You may need to change the sand.
Before you change the sand in you filter, try removing approximately 1” of the top layer of sand, and replace with the exact amount of sand removed. This sometimes rids the sand bed of the deposits clogging the filter.
I could see this, this one seems quite logical. Considering the "junk chemicals" and "magic soups" that a larger part of the industry instructs people to use in their pools.
Also, if that sand had really "worn down", then replacing the top layer wouldn't work. DUH!
Swampwoman said:
Hayward FAQ said:
When do I need to replace my sand?
On average, sand should be replaced every 3-5 years. This may be longer if the pool stays clear, or shorter, if the filter runs all the time. The jagged edges of the sand wear down and become smooth as the sand ages. When this happens the sand can no longer trap debris particles and dirt can pass through the sand and back into the pool.
This is the key here, they seem to think that the sand filter is a "rock tumbler", of which it is not.
It's a compressed bed! Seldom moving.
Swampwoman said:
Hayward FAQ said:
If the pool is chemically balanced, the system is running the proper length of time and the bather load is normal, but the water will not clear, even using a flocculant or clarifier, then the sand needs changing.
Wait, if a flocculant doesn't even clear it, isn't that kind of contradictory? Not that I'm saying flocculants are AWESOME or anything. That just sounds funny to me. That's like blaming algae on the filter.
Swampwoman said:
Hayward FAQ said:
As the sand ages, it may start to clump and the water flow can form channels in the sand, allowing the debris to pass through. Channeling is often seen when the pump horsepower is too large and wants to move too much water through the filter.
Aaah, this is where the reeeeaaalllll truth comes out. Hidden inside that paragraph.
If it's channeled and clumped, well then..... *points finger in air* JUST REPLACE IT!!
Surely that's the solution, YEAH?
Hello??? Try breaking it up and hosing it out 1st. Then if it's still wonkers, replace it. But if you find damaged laterals, or something else when you dive in there. Fix it and put the old sand back.
Unless it's icky and can't be cleaned.
I think that's the key here, the sand can get so raunchy in some situations that it's just not feasable to clean it. So replace it. Doesn't mean the sand is "worn down", it just means it's too gummed up. If you send that sand off, with all the other rescued pool sand, to be cleaned in a plant that does that. Guess what? It'll be juuuust fine!
In fact, they should do that, they should recycle it, have collection stations for that purpose. Then, once the sand is cleaned up, they should sell it at a cheap rate as recycled pool sand.
Makes perfect sense!! But I'm kinda a hippy too.
