Does PH at 8.0+ reduce chlorine effectiveness?
I've read conflicting advice on this. Some say that a PH of 8.0, the effectiveness of chlorine drops to 20%. Others say PH has no effect on chlorine effectiveness. What's the verdict?
From PH - Further Reading
Does Pool pH have an Effect on the Chlorine's Ability to Sanitize Water?​
In a pool with zero CYA, chlorine is more effective at lower pH, but this relationship is much less with CYA in the water to point of being irrelevant.
pH does affect the active chlorine (hypochlorous acid) level that is responsible for most of the disinfection of the water. However, when Cyanuric Acid (CYA) is in the water, it buffers this active chlorine so that pH has far less of an effect on it.
To be specific, with no CYA in the water, going from a pH of 7.5 to 8.0 has the active chlorine level drop by 50%. With CYA in the water, it drops by only 15%. Going the other direction, going from a pH of 7.5 to 7.0 the active chlorine level with no CYA increases by a little more than 50% but with CYA in the water it increases by 35%.
So we generally ignore the pH effect on chlorine except for a SLAM because the larger amounts of chlorine have the pH rise significantly so we recommend lowering the pH first before a SLAM, especially when it's a lot of FC due to high CYA levels.
Reactions: john0886
Thank you!
