Does evaporation leave CYA behind?
ImMikeJones
46
Seattle
Simple question really. I learned the hard way last year that the only way to lower CYA is drain and fill but I was wondering if evaporation plays a role in this at all? If, over the course of a season, you replace a foot of water (just throwing that number out there) does it lower the CYA the same as if you drained and refilled a foot of water?
I leave a simple garden hose in my pool and every night it runs 15 minutes to refill what I lost to evaporation. It's not perfect but it works okay and helps when I am on vacation so the pool doesn't get too empty. My CYA did seem to go down a bit but I also could be imagining things. From my experience last year I had to drain A LOT of water to get it down from 80+ to 30.
You do not lose CYA, salt, or CH with loss of water due to evaporation.
CYA does degrade. Especially if the pool water is warm.
Evaporation leaves behind dissolved solids. It's how distillation works. So things like salt, CYA, calcium, etc are left behind.
This is why areas with hard water and high evaporation struggle with calcium, because they're constantly adding more calcium with each top up but it doesn't go away without draining.
