I've always wondered. The tablets I use are mainly Calcium Hypochlorite, as is the pool shock I use. I'm guessing that the calcium ends up in the water forever. I'm not sure if this is a major source of water hardness, but I'm curious...
Your IC40 should generate plenty of chlorine. Keeping your CYA at 80 or even 90 during July and August can help.I will say that in the height of the summer I've really struggled to keep my chlorine levels up with the SWG alone.
CYA at our pool water temperatures and UV levels degrades by up to 10 or even 15 ppm per month from June to September. Keeping the CYA elevated during the peak UV months helps retain FC levels. If my CYA drops to 70 or below, the FC usage spikes by several ppm per day. At 80 ppm CYA, my FC loss normally is no more than 4 or 5 ppm per day.80 or 90! Gulp. That's a lot higher than I typically have it at. Thanks...
I’ve saw a bit of black algae towards the end of summer last season in one of my pools. I brushed it, increased my minimum FC a little but basically left it till the end of the season. Come autumn I SLAM’ed when the the water was to cold swim.wow.. thanks. While you're here, any advice on black algae?
