When we opened the pool this spring, we had ammonia. There were a lot of worms in the pool after a very rainy winter, and I guess their gut bacteria had eaten the stabilizer and made ammonia. Both CYA and FC were zero on opening; this had not happened the first season we opened. We had to use a huge amount of chlorine to neutralize the ammonia and it was awful. (It was definitely ammonia, because I used an ammonia drop test.)
What do I need to do this winter to prevent a recurrence? This might seem like a silly question, but how do you maintain chlorine with a safety cover on the pool (since you can't just easily lift a corner of the cover to add or test)? And if you do add chlorine, how does it get dispersed with the lines plugged & pump off?
I don't plan on closing until October.
Thanks!
Thanks!
