- Aug 19, 2022
- 77
- Plaster
- CircuPool RJ-60 Plus
I wonder if this question has been posted before (sorry!) — but my search of the forums just turned up information on troubleshooting broken/stuck loop loc anchors…
Do functioning Loop-Loc anchors require any “Preventative Maintenance”?
I'm planning on opening tomorrow, for the first time on my own (yay!). Should I do any “PM” on my brass Loop-Loc anchors before screwing them down flush with the concrete deck?
1) For example, is it worth unscrewing each anchor and flushing the housings with a garden hose? Or is that overkill if they're working fine?
2) What about lubricating the screws? I'm guessing that WD-40 might not be ideal since it can attract more dirt. But should I spray them with a dirt-repelling lubricant, such as graphite or silicone?
3) I know that one of my anchors is slightly loose (the brass housing spins in the concrete, although its screw can still be turned). Should I try to reinforce the connection between the loose brass housing and the concrete, or just leave it alone since it's still mostly functional? If I did, what would I use — 2 part 5min epoxy, or maybe marine adhesive? I saw some TFP threads on this, but wasn’t clear on the final answer.
Appreciate any other advice and tips!
"CYA later!"
Sampo
"CYA later!"
Sampo
