Hi. I am doing a home addition and will have to move my equipment pad. It's going to a new spot in the yard.
While uncovering the pipes to reroute, I realized the return line from the spa is a 2.5" line. All other plumbing is 2", including the spa return. My question is do I really need 2.5 inch or is 2 OK. I'm considering reducing the line at the point I cut in to re-route. The return is from two drains in the spa. One on the lower side wall and one on the floor. It is about an 8' circular spa, attached to the pool with a spill way.
The only potential down side I see is potentially lower flow when running in spa mode. Since there is already higher back pressure from the spa jets anyway it doesn't seem to me the smaller return will have much of an impact. I'll also be upgrading to a 3HP Circupool variable speed pump when I move the equipment.
One more note. If anyone is thinking "don't question what the pool builder did" I don't give that much weight. There are too many bad parts of the setup for me to have any faith in what they did.
Thanks as always.
Thanks as always.
