So you guys prefer to do this than risk sulfates? I'm not saying I cannot do it, or that I'm afraid to do it. But adding muriatic means:
-Buy and safely store muriatic acid.
You would/should do this with dry acid as well as other pool chems anyway = acids & chlorine should always be stored separately.
-Buy and store safety gear.
Most people already wear sunglasses
when working on their pool. Gloves aren’t necessary.
-Get someone to supervise kids while using the muriatic acid, as I can't risk them coming near me.
This is somewhat overkill but could be said of all pool chemicals- even dry acid.
-Some sources suggest diluting multiple 5 gallon buckets before adding it.
Just NO
-Safely dispose of used containers or unwanted acid that could hurt somebody.
This also applies to all/most pool chemicals. Safe disposal entails rinsing the container & putting it in the trash or recycling.
-Properly clean and remove safety gear.
Its not ebola - its a viscous acidic liquid w/ the possibility of some fumes that’s not super splashy if poured slowly. If it gets on your shades rinse them in the pool.
-Be prepared to deal with spills that could etch the patio.
Also could be said of other pool chems. Rinsing spills immediately with water should suffice.
That compared to grabbing the dry acid from my shed and putting a couple scoops in the deep end.
You should do all that’s listed above w/ dry acid as well if safety is a concern. (Minus the dilution of course - don’t dilute either one)
