We’ve had a lot of rain in the last couple weeks and my chlorine level has bottomed out.
SATURDAY: (tested by fancy machine at pool store)
FC: .03
pH: 8.0
Hardness: 320
TA: 80
CYA: 40
(Salt: 2400, set at 15%)
I used the pool math calculator and added 24oz muriatic acid, 96oz of 6% bleach, 2 bags of salt, and an unmeasured amount of baking soda (just threw some in
). I’ve never needed to SLAM before and I expected this amount of bleach and other chemicals to basically fix things. I tested again today, thinking I would just need to fine tune things like pH, TA, CYA and SWG settings. Nope.
The chlorine is still way off.
MONDAY: (tested by me at home)
FC: .5
pH: 7.8
Hardness: 300
TA: 95
CYA: 40
(Salt: 3115, set at 25%)
My pool water still looks clear. Do I need to SLAM?
Should I SLAM or just add what pool math calculator says to add (75oz of 6% bleach, 19oz muriatic acid, 13oz baking soda, Zero CYA stabilizer, 10lbs salt) and then turn up my SWG percentage?
If I need to SLAM, I’m having trouble understanding the chart for my target FC and Shock FC levels. The SLAM directions say that the ideal CYA level for a SLAM is 30-40, but the chart for SWG pools says SLAMing at CYA levels as low as 60 is not recommended. My CYA is 40. Do I raise the CYA before SLAMing? At the bottom of the screen for the pool math calculator, it says “Shock: 16” so is that the target number for my shock level if I SLAM? Has that number already taken into account the fact that my CYA is 40?
*****edit*****
Problem solved! I did the math wrong. My FC is not .5, it’s 5!!!
FC: .03
pH: 8.0
Hardness: 320
TA: 80
CYA: 40
FC: .5
pH: 7.8
Hardness: 300
TA: 95
CYA: 40
*****edit*****
