Do I need a new seal plate?
Jun 9, 2014
213
Marietta, GA
I am replacing my motor due to bad bearings, and when I removed the seal plate and mounting plate from the motor, I noticed they were looking like this. Can I just clean these up, and reinstall with the new motor, or do these look like they need to be replaced? Obviously there is a lot of corrosion due to water getting in, so I wasn't sure. Thanks!
So I just replaced the motor, and turned it on, and all I hear is a faint humming, but it is for sure not spinning or anything. Any suggestions? I have read it could be incorrect voltage, stuck impeller, or bad capacitor. It is a brand new motor. I am running it in 115, and I moved the jumper from 230 to the 115 spot. I ran the black and white electrical wires to the same screws that they were connected to on the old motor. Ideas to look at?
Here is a pic. I noticed on the old motor, that the jumper was in the 230V position, but I am pretty sure my setup is 115V, so I moved the jumper to the 115V position. As far as the shaft spinning freely, when I pulled the motor from the pump, and tried turning the plastic piece attached to the shaft, it turns, but is does take a little force. I wouldn't say it spins like a top or anything.
I think I may have figured it out. The black wire is supposed to be in the first screw, not the one by the jumper. I actually didn't think it mattered which terminal the black and white wires go to, but I just read that it should be the opposite of how I did it, so I am going to swap the wires and see if that does the trick.
I did not touch the jumper on the old motor and it appears to be in the 230V position. If my wiring was 230, then wouldn't I have black, red, and green wires, instead of black, white, and green? Here is my timer wiring. I will go test the voltage, but I am 99% sure it is 115V.
People don't always use the correct color wire.
That's why I always test the voltage instead of assuming what it is from the wire color.
The below picture looks like the 115 position.
So, you might be correct, but test anyway.
