- Jun 13, 2016
- 115
- Vinyl
- Pentair Intellichlor IC-40
I opened the pool a few days ago and I noticed some brown sandy looking substance on the bottom of the pool. Most of it was along the seams of the vinyl liner. I vacuumed the pool and left it as is.
Today, I opened up the cover and saw the same brown substance. As some background, we're still not using the pool, the water temp is only about 55 degrees (this is MN!). I'm just still in the early stages of making sure the pH, chlorine and CYA are all at the right level. Obviously too cold to run the SWCG so that is off.
I added chlorine three days ago and tested it then. It was at 4. I tested it again today and it was 3.5. There was no combined chlorine either day. pH has stayed at 7.4.
So, the question is, is this algae?
See the attached pictures. The one picture shows the deep end of the pool and basically, how clear the water still is. The second picture is showing a little bit of the suspect brown substance near the top of the picture on the right hand side of the seam. Most of it is along seams, but some of it is just kind of "pooled" randomly around the pool.
