Do I have a leak?
Obecalp86
51
Phoenix, AZ
Saline Generating Systems Breeze 540
Hi all,
I’ve had a tiny suspicion about a leak over the summer based on the auto valve being on a “lot”, meaning a soft intermittent “hiss” as it releases water (although we’ve had a record summer in Phoenix) and my salt level dropping as follows:
7/4: 3800
8/31: 3600
9/28: 3200
In the same period of time, my CH has gone from ~320 to 400 (my fill water is ~175ppm).
I did the bucket test - the tape was placed right at the water line outside the bucket, but probably 0.1 inch in the water on the inside, which I adjusted for in the pictures taken at 24 hours (see attachments). I also added a picture of the vigorous flow from the auto filler once I turned it back on.
Do I have a leak? Of note, our water consumption varies wildly month to month (we were mostly away all of July), but usage past few months seems in line with prior use).
Should I repeat with a see-through bucket to make this test easier?
Thanks all!
Edit:
- I cleaned filters last week and lost at least 10-20 gallon to bleeding air out of the filter housing, draining the filter etc
- Definitely no leak around the pool equipment
- pool patio is concrete and surrounded by pebbles, so I imagine a leak would be hard to spot, but at least there are no soft areas
0.25” water loss in 24 hours can be evaporation.
But the water loss from the pool is about 0.8 inch and the difference between inside/outside the bucket is at least 0.15 inch. How big of a difference is “significant”?
More then 0.15”.
Evaporation will leave CH and salt behind, a leak will take CH and salt with it. The auto fill will replace the CH but at a lower level of about 150. Your salt level would go down with a leak but your CH should go down too. Your CYA would also be depleted quicker than normal.
I understand these simple principles well, but how do you explain the drop in salt level? I think I lose 10-15 CYA per month (at least when water temps are in the 80’s-90’s), but I supplement my SWCG with old pucks specifically to get my CYA up (target is 80, I’m currently at 60, and started with 30ppm 3/2024 after I replastered my pool), probably at least meeting the loss of CYA from water temps. Also, I think it’s hard to make sense of a stable CH when my supply water has a CH of 175ppm as this makes CH loss from a leak less apparent.
I’ll post see-through water bucket test pics later today.
I tried the clear bucket method and get differences (lower waterline on the outside) from 0.2 inches to 0.3 inches (see pics - the ruler is in cm and I converted it to exact numbers in inches).
I didn’t realize how difficult this test is.
Is this conclusive or is there some other test I can do? I would rather not pay $600 to a leak detection company to be told I don’t have a leak.
Just in case anyone might find this useful - I redid the bucket test with a better (easier to see) setup after my salt level dropped 800ppm in a single month.
The bucket test is clearly positive - see pic.
Leak company coming out this week to do pressure testing. Will add a comment once I have results.
Trust the bucket test.
