Mods, feel free to move this to a more appropriate place.
So for the past few years, I've had a slow (although how slow varies with things like the season) leak in my spa. It's a shared equipment setup with the pool, and while there are check valves on the return side, the way the plumbing is set up, I don't see how they could be the source of the problem even if they're bad. First off, a picture of my valve setup to assist you in... assisting me:
This is how my pool operates 99% of the time. Pool config (so the spa side of the inlet and return are closed by the valves) and waterfall valve closed. The waterfall is a return to the bottom of the spa, pretty standard stuff. In this configuration, I still get water loss in the spa. So question 1 is: If the check valves were bad, wouldn't the 2 way waterfall valve and the spa diverter both also have to be bad for water to back fill into the pool?
That, along with the fact that the water level seems to settle just below the return jets on the spa leads me to believe it's a leak in that part of the system somewhere. Question 2 is then: What other self diagnosing can I do to narrow down whether or not it's actually a leak? and finally, question 3: If it *is* a leak, is there anything I should look for/look out for when selecting someone to do the locating and repair? Or is it DIY-able (current skill level is - I do all my own maintenance, and I just replaced the timer/controller myself and plan on installing the SWG cell myself too)?
Our heater is currently out of service (look for a thread on that soon!) and with my new controller cycling the spa and pool modes every 30 mins for freeze protection, I guess it's finally time to tackle some deferred maintenance so we can get a bit more enjoyment out of our pool!
