Hey all,
There is a good chance I will be attempting this job myself. Contractors are terrible about getting back to me and the one guy I had lined up just pushed me back a couple of weeks due to equipment failure.
Heres the issue:
Was losing a lot of water last season and had my liner checked for leaks. - No issue.
Early this month, I had the piping tested and found leaks in all 3 of my return lines. Pool was built at the time of the house so piping is 30+ years old and is the black poly (I believe).
All my piping is 1.5" and I have a simple setup. Pump, sand filter, 1 skimmer, main drain, and 3 returns.
My plan is to dig around my pool skirt which is all dirt/grass currently and lay new pipe in the ground. I plan to also replace my skimmer line only because one of my return lines will run directly past it and don't want it to become a future problem. Main drain I am not touching.
My questions are:
When it's time to connect the new return to the old/existing return in the pool, should I replace the whole return fitting? Or cut back a foot or so and make connection to new pipe? Also, can the returns be piped horizontal? Or do i have to dig down just before and put a 90 to go up and a 90 to go horizontal to pool?
Also, when I pipe my returns from the filter, I want to make a manifold of sorts for the return lines to isolate each one. Is there a valve that will split 1 pipe into 3 more? Or just make a line with a tee that has a valve after each, and a second tee?
I assume there is a better way to do this, but cant think of it now.
Also, I have a concrete skirt that is about 3.5-4" inches thick. Is it difficult to cut, repair small areas to replace the pipes?
Sorry for the length of this.
Any questions/ideas will greatly be appreciated. Thank you!
Heres the issue:
My questions are:
