I wonder if the high FC is causing an abnormally low pH reading?I'm really concerned about that pH and TA. Are you (or your wife) 100% confident in those two results?
Very good. Go in stages, letting the water circulate the Borax or baking soda for about an hour before re-testing as to not over-shoot too high on either item. Once the pH gets close to 7.2 you're in the safe zone. TA at least 50.She is in her way to get baking soda and borax now.
No, it's not high enough to skew the pH test. It also would have no impact on the TA.I wonder if the high FC is causing an abnormally low pH reading?
New levels after borax and baking soda:I'm really concerned about that pH and TA. Are you (or your wife) 100% confident in those two results?
Much better!I think it’s time to open this pool is open for business?!?
With no plaster products in the water - no. The only other item that might require some CH is a heater, but it doesn't look like you have one. Now if you have some extra cal-hypo laying around and just want to use it up, no problem. Just be mindful of the CH level over time so it doesn't get too high.Should I worry about the Calcium Hardness being low?
Hahahaha what on earthOkay. Got pump and filter up and running last night. Added 4lbs of stabilizer via sock method. And close to 2 gallons of 10% liquid chlorine. This is the only test that has been ran (my wife ran this while I’m at work). Based on this alone, what should I add when get home? View attachment 591869
I assume you didn’t read the entire thread? Hahaha what on earth…Here is a comparison from my pool:
PH is mega super high because I just dumped a bunch of baking soda in to try and tweak my LSI. But anyway.
My guess is you have way way way way too much chlorine in which is affecting the PH reading to be invalid basically.
Here’s today’s for comparison.Here is a comparison from my pool:
Thanks!
Another issue I am having trouble finding a solution to, is a pool ladder. Obviously with it being a semi-inground, I need a ladder that is shorter on the outside of the pool than the inside. I can't seem to find much information on this. It is worth noting that the ladder will be temporary until we can get the deck built (likely next season). At this point I am considering a cheap A frame that I can modify by chopping off the legs on the outside of the pool to fit my needs until the deck is built. Anyone have any experience or thoughts on this?
This is precisely what we did! Thanks!It sounds like you have your pool open, so you likely came up with a solution. I would have bought the ladder / stairs that I want as my permanent stairs, and built a small temporary platform for them on the outside of the pool.
Timer question... Im running a 1.5hp 2 speed pump that has a rocker switch (middle is off, HI and Low). I am currently running the pump on a 12gauge extension cord rated for the appropriate amps. I will be hard wiring in the off season when we build the deck. Is there a timer I can use now with the extension cord setup that will run both speeds of the pump, and then reuse the same timer when we are hardwired?
Pump voltage is 120
Your second option seems most reasonable. Thank you for that suggestion!
Do you have any recommendations for a regular timer?
