Discoloration in Spa Plaster (Not in Pool) – Seeking Advice
calisoldier
110
CA
Jandy Aquapure 1400
Hello!
I’m hoping someone can help me figure out what’s going on with my spa. As you can see in the photos, there’s noticeable discoloration and blotchy staining in the spa area of my pool. What’s odd is that the main pool doesn’t have this issue—it’s isolated to the spa only.
I’ve tried scrubbing with a brush and even rubbing a chlorine tablet on some of the spots, but it didn’t really make a difference. That makes me wonder:
  • Could this be a plaster issue (like mottling or mineral staining)?
  • Could it be due to water chemistry differences between the spa and pool?
  • Is there anything I can do to treat or reduce the appearance of these stains?
The plaster is about 6-7 years old, and I try to keep my water chemistry in check. Any thoughts or experiences would be really appreciated!
Could be iron or copper stains.
Nope.
Polish the areas with diamond sanding blocks or a power sander...
Nope.
Sorry if this is a silly question, but do I need to drain the spa before attempting this? Also, if I polish specific areas, will they look noticeably different from the unpolished sections? What about areas where there’s pitting — how will those turn out?
