- Jun 5, 2011
- 1,316
- Plaster
- Jandy Aquapure 1400
When I drain my DE filter to clean it, the pump basket fills with dirty water, which I assume is flowing back from the filter. After cleaning the filter and starting the pump, that water them flows into my pool, most notably in the spa since that has the largest return. It makes the spa and pool cloudy, but clears up in a few hours. I’ve had the pool for 14 years, but this just started happening in the past year or 2. I’ve read where you can put the backwash valve in the backwash setting to prevent water from flowing back into the pump basket. Is that accurate? Any other fix? Kind of ironic to clean the filter only to end up with a cloudy pool. I’ve posted some pictures below. Thanks for any help!
Filter basket getting dirty water as filter drains:
My backwash valve:
My backwash valve:
