T Turbolag Member Apr 6, 2023 22 Crownsville, MD Mar 26, 2025 Add bookmark #1 I have a tight spot next to one valve that I plan to automate. I cannot find specs of the GVA-24 anywhere. Anybody have that? tnx
PoolStored TFP Expert Gold Supporter TFP Guide Jun 24, 2021 15,880 Ashtabula, OH Pool Size 29000 Surface Vinyl Chlorine Salt Water Generator SWG Type CircuPool RJ-60 Plus Mar 26, 2025 Add bookmark #2 No depth...but may help...
J JamesW TFP Expert Mar 2, 2011 51,689 Mar 26, 2025 Add bookmark #3 Unit Carton Dimensions (H x W x L) in 5.251 x 6.751 x 8.251 in https://djuly1j3idynn.cloudfront.net/userfiles/images/inriver/original/182962_intermaticvendor1_pe24va_technical_data_en.pdf https://djuly1j3idynn.cloudfront.net/userfiles/images/inriver/original/9935_pe24va%20instructions%20en.pdf https://www.intermatic.com/Product/PE24VA Attachments 9935_pe24va instructions en.pdf 699.1 KB · Views: 0 Reactions: PoolStored
J JamesW TFP Expert Mar 2, 2011 51,689 Mar 26, 2025 Add bookmark #4 https://www.amazon.com/Yoursme-Actuator-Replacement-Rotation-Compatible/dp/B0CR7K8VFD https://lesliespool.com/intermatic-pe24va-valve-actuator-24v-60hz-0.75-amps/221046.html
T Turbolag Member Apr 6, 2023 22 Crownsville, MD Mar 30, 2025 Add bookmark #5 Thanks for the dims everyone! Reactions: JamesW
J JamesW TFP Expert Mar 2, 2011 51,689 Mar 30, 2025 Add bookmark #6 TFP is a registered 501(c)3 non-profit that is maintained by user donations. The people who answer questions are volunteers. If you find the site to be a good resource, please consider making a donation to help support the site. Thanks. Become a TFP Supporter Help Support TFP Trouble Free Pool is run by a dedicated group of volunteers that … Read more… www.troublefreepool.com
