Hi everyone!
I would like to add heat pump to my indoor pool and have a dilemma on its placement, thus would like to get your view, what to consider and I might be missing.
As illustrated in drawing below: either to go route A placing it in the open shed, more work, not perfect airflow, but easier to maintain and probably less RPM needed for my variable speed pump.
Or B route running pipes directly through wall at ceiling level, shorter distance, but increased pumping height by 2.6m/8.5ft and harder to maintain. We have freezing temps during Nov-Feb, thus winterization is important - at that height I would need to figure how to do it from inside, was looking at solar panel systems using pressure relief valve to auto drain once pump shuts off.
What are your thoughts?
