I've seen a couple similar threads on the forum but haven't seen a solution for my situation:
Behavior:
After switching on circuit breaker (time 0:00) and enabling boost I hit the "test pool pilot" button every 20 seconds or so for several minutes.
The voltage initially climbs from 0/6.5A to 22V/5A in about 30seconds then slowly falls back to 0V/6.5A over the next 20 minutes.
While it's dropping from 22V to 1V the current stays around 3.9-4.1A, then when it finally reaches 0V the current begins to climb to settle at 6.5A.
During this settling to 0V time the Check System light flashes with the message "Check/Clean Cell".\
After about 10 minutes, even if I hit the "test pool pilot", the "Check System" light no longer flashes.
*** I replaced the cell and tri sensor with brand new units, but the behavior remains unchanged. ***
I took an Ohm-meter to everything I could think of, but nothing seemed unusual.
I'm out of ideas. Any help would be greatly appreciated.
Erik
Behavior:
Erik
Time | Salt | Temp | Volt | Current | Check System | Message |
0 | - | - | - | - | yes | ? |
0:26 | 1600 | 77 | 0 | 6.5 | NO | NO MESSAGE |
0:46 | 2700 | 78 | 22 | 5 | yes | check/clean cell |
1:07 | 2800 | 80 | 18 | 4.2 | yes | check/clean cell |
1:28 | 2900 | 82 | 16 | 4.1 | NO | NO MESSAGE |
1:47 | 2900 | 82 | 15 | 4 | yes | check/clean cell |
2:03 | 2900 | 83 | 14 | 3.9 | yes | check/clean cell |
2:21 | 2900 | 83 | 13 | 3.9 | yes | check/clean cell |
2:40 | 3000 | 83 | 12 | 4 | yes | check/clean cell |
2:58 | 2900 | 84 | 11 | 4.1 | yes | check/clean cell |
3:17 | 3000 | 84 | 10 | 4.1 | yes | check/clean cell |
3:35 | 3000 | 85 | 8 | 4.1 | yes | check/clean cell |
3:53 | 3000 | 85 | 7 | 4.1 | yes | check/clean cell |
4:11 | 3000 | 85 | 7 | 4.1 | yes | check/clean cell |
4:25 | 3000 | 85 | 6 | 4.1 | yes | check/clean cell |
4:43 | 3000 | 85 | 6 | 4.2 | yes | check/clean cell |
5:03 | 3000 | 85 | 5 | 4.2 | yes | check/clean cell |
5:21 | 3000 | 85 | 4 | 4.3 | yes | check/clean cell |
5:39 | 3000 | 85 | 4 | 4.2 | yes | check/clean cell |
5:57 | 3000 | 85 | 4 | 4.1 | yes | check/clean cell |
6:11 | 3000 | 85 | 3 | 4.1 | yes | check/clean cell |
6:46 | 3000 | 85 | 3 | 4.2 | yes | check/clean cell |
7:07 | 3000 | 85 | 3 | 4.1 | yes | check/clean cell |
7:23 | 3000 | 85 | 2 | 4.2 | yes | check/clean cell |
9:23 | 3000 | 85 | 1 | 4.4 | yes | check/clean cell |
20:00 | 3000 | 85 | 0 | 6.5 | NO | NO MESSAGE |
