- Jul 12, 2021
- 77
- Plaster
- Pentair Intellichlor IC-40
I have just installed an Intellicenter with a SWG in my existing pool setup, and have a question I couldn't find an answer to... why is there such a difference between the manufacturer (Pentair) chemistry recommendations and those here at TFP (and in my PoolMath app)? Particularly the following:
I've had nothing but great luck following the advice for maintaining my pool found here, but get a little nervous reading the warnings from my Raypak (heater) and Pentair about FC levels above 4 PPM causing "corrosion of metal components."
Can someone explain the differences, and why I shouldn't be worried about damaging my equipment with the higher FC levels suggested?
Thank you!
Measure | Pentair Recommendation (PPM) | TFP Recommendation (PPM) |
Free Chlorine | 2-4 | 4-6 |
Cyanuric Acid | 30-50 | 60-80 |
Total Alkalinity | 80-120 | 60-80 |
Thank you!
