Hi folks. I've been silent all summer because we ended up unfortunately NOT opening our pool this year. In the spring we had a windstorm which blew some of the cover into the pool and let some leaves/debris into the pool. I covered it up immediately and knew it could get bad but did plan on opening it based on advice here on the forums. But, we didn't due to life circumstances. It's going to get cold here (had a bit below freezing last night, again tonight). It will warm up the next 9 days between 49-70 F high to 34-50 F low after tonight's 32. Water temp was 58F.
I know this past behavior isn't what we do here....but.....is it still worth hooking up everything and SLAMMING over the next week or however long it takes to clean and balance the water for 'second closing'? I had trouble once adding CYA to colder water and it took forever to dissolve, and doing all this work right now would be a pain. But if there is risk to the liner or something other than just a possibly green pool at open, I will do it. Here is the state of the water: puffs of brown colored stuff on the bottom, clear water, slightly slimy sides of the vinyl liner and a mild swamp smell. What could happen, damage-wise, if I do nothing and wait till spring to open as early as possible?
Here's what it looks like now. I checked 3 areas and they are all similar. Thanks in advance for your input. Trying to make the best of the situation I'm in right now.
