Diatomaceous Earth....how much?
May 19, 2016
129
St Catharines, Ontario, Canada
I would like to add some DE to my sand filter and am wondering how much? The smallest bag I can get from the pool store is 10lbs. I read the article on DE and it explains how to add it well enough but I am a bit more confused about how much to add and when to stop adding it. How many pounds should I expect to use ? Is the end game to add 1 PSI to my filter pressure and then stop adding? And if so, at what pump RPM? Any further tips, tricks or advise is much appreciated.
Thanks
S
As the directions for adding state.... start slow and note your initial pool filter gauge reading. Add say, 1/2 cup... wait 5 minutes or so and go see if your pool filter gauge raised any? If 1ppm increase, stop adding. If it didn't increase, add a little more and recheck.
My pool takes about 3/4 cup.
I have a single speed pump so I can't comment on your ideal speed.
Maddie :flower:
