Hello, Could use your advice.
Our diamond bright plaster (installed Oct. 2005) is very rough to the touch. Tears the skin off your feet. I've been member of TFP for 4-5 years I think, and I've been very vigilant about keeping the water balanced using my Taylor FAS-DPD K-2006 kit. Below are my latest numbers. I'd like to mitigate my situation with the plaster ASAP. I don't go to Pool stores anymore thanks to you guys. I use only liquid chlorine (from Walmart), Muriatic Acid, Backing Soda (only when numbers call for it), I do use 3" pucks in a floating chlorinator device. That's pretty much it. I've read that the rough plaster could be calcium deposits? Maybe I don't brush as much as I should, guilty. But I do need help.
FC = 3.0
CC = 0
PH = 7.4
TA = 80
CH = 290
CYA = 35
Current Water Temp = 84 F (north-east NJ)
Thank you,
Adrian
FC = 3.0
CC = 0
PH = 7.4
TA = 80
CH = 290
CYA = 35
Thank you,
Adrian
