We've owned our home with pool for several years and just drained the water due to high CYA. While the water was out I took a look at the main drain since we've always had an issue with debris not clearing out of the pool. I took the main drain cover off and found a plug in the main drain. Based on some other posts, I understand I may have a leak. Would appreciate any guidance on how to best troubleshoot the main drain.
I took the plug out and put a hose with a ballon-type "clog buster on a hose and put it in the main drain. I was hoping to see water come out into my pool pump, but saw water bubbling up from the ground about 5 feet from the pump. I dug up the pipes and discovered the main drain pipe was cut and not even plumbed into the system! The pool as only been working from the 2 skimmers and 2 wall drains.
Here's a video of the pool and main drain issue:
6/2018 Pool Drain Issue - YouTube
So my question to the forum: What's best way to troubleshoot and potentially address issues?
- I bought plugs for the drains and one plug with an air valve allowing me to pressurize the disconnected main drain pipe. Will pressurize with 15psi and see if ti holds. If it holds I should be able to tee the main drain line in with the other two wall drains.
- I bought dye in a syringe and will check if there is any leak once I remove the plug from the main drain. I noticed there is a bunch of what looks like concrete in the main drain box. I'm wondering if this is the result of a prior repair.
Anything else I should consider? Really appreciate this community and welcome any advice!
-Dan
-Dan
