Desperation
One can clean sand without changing it out.
Sand rarely needs changing out unless its gummed up with FLOC or Clarifiers, or Baqua.
With mustard algae filtering thru it? I think this is the best route. I've been SLAMMING this pool since 05/25. It has not cleared and I cannot physically continue that route. Scrubbing an empty pool seems do able.
However I don't want this algae being introduced via filter once I have a clean pool.
Thanks
I remember you saying he was testing up until recently just was curious if he too was counting one drop as one or if he was multiplying by .5. But now you know. Good luck with your drain/refill. Hope y’all are able to swim soon!
Why are you adding MA? Your pH is inaccurate with FC above 10ppm.
I just stated I'm new at testing. I made an error on my calculation. So I'm draining and refilling. To #1 clean/kill this algae. #2. Get my chemistry right.
I will post the new refill and accurate readings. Hopefully in the future. Thanks for everyone's help.
Reactions: Tena
Good luck! ?
Don't feel bad about the testing, I've done it for years with just two reagents and a pool store, so it's new to me too. A bit of a curve, but worth it I think.
Reactions: CDC
