You can use the vacuum to draw water from the bottom of the pool to help improve circulation. A couple of things to keep in mind, one a sand filter is going to take longer to filter out dead algae and other organic debris, and two, you have a relatively small sand filter for the size of your pool. Keep the slam going and resist the temptation to add anything other than liquid chlorine to your pool. There is no quick fix that gives instant results.
