Had to go away for 3+ weeks- I came back and the pool is a mess. Green. Yea.
Prior to leaving I had tried the bottle of algaecide and it made no dent - and I knew I'd have a fight on my hands when I got back.(approx 30K gallon pool with sand filter in Charlotte, NC) I'm no pool expert- and not nearly as technical as you guys here on the forum.
So with rain coming I grabbed a bottle of FLOC and added it last evening knowing I could use rain (on the way) water to assist refilling the pool.
In the past FLOC has been the miracle to crystal clear water that I couldn't get balanced. Typically 6-12 hours was all it took. Today ((13 hours later)) it looks the same.
So this morning I have read a bunch of your pool school articles and am kicking myself for not getting rid of the algae first. But before I start down the road to SLAM...
My first question is what to do about the FLOC. I will likely let it sit for the full 48 hours BUT I do not expect it to be the miracle I expected of all the bad stuff sitting at the bottom of the pool. I will assume after 48 hours the pool will still be green and terrible. Is it safe to turn back on filter as I go after the algae? I am assuming I may have to backwash quite a bit and then clean the sand once I have a clean pool but I dont want to harm the filter in the process either.
Thanks for the guidance.
