- Jun 22, 2018
- 85
- Vinyl
- Pentair Intellichlor IC-40
My sand filter was installed in 2014. I was prepared to replace the sand but after reading here I discovered a cleaning would do basically the same! So I opened the filter yesterday and discovered a) the diffuser and air tube were pushed to the side, not vertical like they are supposed to be and b) I was about 100#s short on sand!
Today I deep cleaned the filter and added two bags of sand. The backwash was extremely dirty but it cleared after a bit, same with the rinse. I thought I had isolated everything but I didn't....I should have taken out the SWCG so that I had a gap between the pump and the returns... painful lesson learned. Brown stuff shot into the pool for what seemed an eternity but was probably about 15 seconds.
Now my previously sparkling, just-off-a-SLAM pool is slightly cloudy. I don't have a way to measure FC/CC since I am out of reagent but I do have a Taylor CL kit that will let me know if it's above 5ppm at least. And getting ready to go on vacation in less than 36 hours...I dumped 2 gal of 10% bleach in - based on yesterdays' readings that should get me back to SLAM levels. man oh man!
