Help with proper fix/product.
Started with a suspected pool leak. Did't intend to pull tile off, but hollow sounds made me suspicious and the loose tile coincide with the sidewall cracks in pebbletec. Above each of those areas is an expansion gap in the decking. I'm no pro, but it seems to me water leached down from the decking and started the damage. Is this correct thinking? I 've scraped out nearly the entire top gap of the perimeter of pool and intend to use a silicone product and seal the top line of the tile. Is that proper?
Question...what is the best fix for the decking? I was going to use a siliconized concrete product and pump that in the gap above the tile. I'm going to chip out and grind down the pebble cracks and patch with a pebble patch product that is available here in az. Not perfect match, but I can live with it.
2nd question...Reattaching tile. I have an adhesive mix for water application and grout that is also pool rated. However I'm unsure what to do at the bottom of tile where it meets the pebble. Do I grind out a gap and patch that, or can I set tile in a thin layer of epoxy or similar? My guess is grind out a small strip and patch in after tile has set.
A couple photos of deck, tile, crack, pebble....headache. Feedback appreciated. Thanks.
Jeff
Jeff
