I am having a pool built and I am planning to add the plumbing for future deck jets and waterfalls prior to back filling. My idea is to add 10 standard cmp deck jets. I am plumbing 2 of them as home runs in case i decide to upgrade those to laminar in the future. My original plan was to run a dedicated line to each side and connect 4 deck jets:
In doing some research here it seems a loop is recommended to help with even flow. Id like the ability to control each side individually so connecting both sides to have all 8 on 1 loop wouldn't work. I'm trying to find out the best way to go about this. Is my only option creating a separate loop on each side as below?
The deck jets accept 3/4", I was going to run 2" out on each side and reduce it at each T to 3/4".
Would i be better off to just run 3/4" home runs for each jet from the pad? Even with the smaller 3/4" pvc i think it would be quite a bit more expensive with all the extra pipe needed. Being able to fine tune each one would be nice though.
Or maybe 10 is overkill and I should just stick with the 2 diagonal home run jets. I initially started with 6 jets but kept adding them to "even" it out.
Any help or tips anyone can offer is appreciated. Thank you in advance!
