Long story short, I had issues with calcium buildup and scaling on the walls of my pool, I tried a "calcium treatment" kit, which from what I understand was Sulfamic acid. Following advice from TFP @JoyfulNoise, I exchanged the water to get the acid out of the water. The kit did work, but I'm having issues again with this "soft calcium" building up in the pool. It's accumulating in the "splash pad" part of my pool and the vacuum fills up with this stuff. I attached a picture to show the contents of the vacuum. Here's my pool readings:
FC - 6
CC - 0
PH - 7.5
TA - 90
CH - 225
CYA - 70
Salt - 3200
Temp - 87F
CSI - -.036
Any advice on why this is building up still with a negative CSI? I feel like this isn't a common problem and I'd like to prevent it from happening.
FC - 6
CC - 0
PH - 7.5
TA - 90
CH - 225
CYA - 70
Salt - 3200
Temp - 87F
CSI - -.036
