When my pool was opened this year, I was going through a company to balance the water for me (Pre TFP). I just assumed they were taking care of it, but I started noticing white flakes shooting out of the returns, and heavy white staining in these areas as well. I do not know the exact values of the chemicals, but my CYA was around 30, the PH was around 8.2, and my salt levels dropped to about 1,200. Water temp was 88 and CH around 250, which puts my CSI value at close to 1.0, so I'm assuming that was the cause for this initially. I have a two part question now:
1) - Will the scaling on the floor of my fiberglass pool fix itself with a balanced pool and a CSI value in proper range?
2) - I'm still seeing some flakes in the water, and the pool vac is picking up A LOT of calcium deposits. Are these from the SWG, or possibly the scaling lifting up? If these are new from the SWG, how do I prevent this from happening? They have not been causing the calcium deposit stains to worsen to the best of my knowledge.
Here are my most recent test values, they have been this way for a couple months now:
TC - 6.6
CC - 0.2 or less
PH - 7.6
Alkalinity - 90
CH - 250
CYA - 60
Salt - 3200
Water Temp - 88
CSI - -0.18
TC - 6.6
CC - 0.2 or less
PH - 7.6
Alkalinity - 90
CH - 250
CYA - 60
Salt - 3200
Water Temp - 88
CSI - -0.18
