10,000 gal pool fiberglass and plaster, TA 130, CH 100, ph 7.2, Temp 80. Problem - Monday started out with TA at 280 (Well water). After 1 gal acid TA came down to 205. After 2 gal of acid, TA came down to 160. Added a qt of metal out and another gal of acid - TA is now 130 !
On a 10000 gal pool and 3 gal of acid, my TA should be less than zero !!
I acid washed the brown grit off the entire pool and filled with fresh water - installed a new pump and new cartridge filter. Then started this process - am getting freaked out by all the acid I’m using ... help ?!?!
Acid is Muriatic from Menards - 31.45 HCl 20 Baume
