Same problem. I had this situation before, 2 years ago. Starting with a clear and balanced pool, the EC65 began to clog quickly, within an hour or less. Back then I researched and investigated all I could, got a lot of ineffective advice, all the while the pool turned cloudier by the day.
In the end, I bought a whole new filter because it was less money than for the parts. Within a day, everything cleared up and the filter ran fine.
Now I am at this point again, and I just want to throw out the Hayward filter altogether once and for all. The issue is not with the water, chemical balance, with algae, or with some other controllable parameter. I believe that these filters are failing mechanically somehow.
Like you, I have taken it completely apart, cleaned it and replaced any fingers that seemed damaged (I am on my 4th filter in 10 years of pool ownership and have a lot of spare parts to experiment with ...). When I put it back together, the problems were back right away.
Somehow a new tube nest works and the old one doesn't, even though there is no visible difference.
I went through the process again yesterday. I washed the filter with the host until there was no DE residue visible, flushed it, sprayed it with filter cleaner, soaked it in the bucket, put it back together, and ran the pump overnight. In the morning there was almost nothing coming out of the jets. I pumped the filter a few times, turned it back on, pressure was normal. Came back after an hour, same situation as before. At this point there is only DE and water in the filter (at least nothing else I can see).
I am really not sure what to do now. The price of the EC65 went up and it costs almost $200 more than 2 years ago now. I can't keep doing this. There must be a better solution?
