Hi All,
So this is year 2 of battling my pool. Year 1 was way worse, but year 2 has still gotten off to a rocky start.
To start the season off I've performed a deep clean of all the grids and they looked great. I noticed there were a couple of "ribs" broken in the grids, but they were individual and no adjacent areas of two or more broken "ribs" on any single grid. I reassembled the filter and closed it up. After starting the pool everything seemed about right; however, after charging my filter pressure shot up and no matter how much backwashing I performed, pressure never decreased. I reopened my filter and performed another deep clean, all of the grids had a deep green colored algae covering them.
I have since switched over to recirculate mode on my equipment and started the normal "SLAM" treatment to try and kill the algae. My main question is: is it likely that the algae was clogging my filter and, because I hadn't killed it, I couldn't backwash it off of my grids? Or what could be the culprit on why I couldn't successfully remove the algae from the grids during backwashing?
A follow up question is: I have a DE filter that I've just switched from cellulose fiber to actual DE. Isn't DE supposed to be easier to backwash off of grids so I don't have to open my filter multiple times a season?
As always, thank you all for your help. It's very much appreciated.
