"DC voltage too low"
oh-DIY-io
57
Ohio
UPDATE - Turned out to be wired for 110v. Quick fix!
New installation of a Hayward variable speed pump. The electrician that wired it (and the Hayward Pro Logic controller) isn't a "pool guy".
I'm getting an error message that says, "Check System. DC voltage too low". The only troubleshooting I can find from Hayward says to cut power for 1 min and restart. That's not working.
I'm starting to wonder if it's not wire correctly.
Any ideas?
Thanks!
Bryce
Did the electrician wire the pump for 240V?
You check with a multimeter across L1 and L2 at the pump that you have 240V?
Post pics of the CB and pump wiring.
