Dark Buster or not? Lights for pool.
R6bbie
44
IL
CircuPool Core-35
Hello and thank you very much, should I use this light or is this a bad idea and maybe something else might be better, the fitting and the flow…. it’s not looking good for flow. ?? Small oval 15x26
What flow difference are you seeing with the light installed?
What style return did you have before the light?
On high speed or low speed on your pump?
I have yet to install it, or even the one that came with the pool. Install of pump and whatnot is tomorrow.
I was asking about it, I was hoping someone had one, thanks for the reply.
