Hi,
I just purchased a Cyclone blower and am trying to determine the best adapters and connections to use in winterizing my pool. I have Pentair pumps and separate systems for a negative edge/vault and a poolside spa. Blowing out through the pumps makes the most sense with this system. On the pumps, the intake from the main drain and skimmer seems to be about 1 1/2 inches and I purchased that size of hose. The outflow (to the filter and eventually the returns) seems to be 3 inches and then tapers down. What connections or adapters could I use? Is it possible to connect to the pump drain holes? Thanks so much for any help.
