Can someone explain how CYA impacts the effectiveness of chlorine? I understand that CYA helps preserve/protect chlorine from sunlight. How does that work? Does it combine with and protect chlorine, keeping chlorine from working as a sanitizer below a certain level, depending on the level of the CYA? In other words do you have to have a chlorine level above and beyond a certain point, depending on the CYA level in order for the chlorine to work as a sanitizer?
