- Aug 20, 2020
- 7,877
- Plaster
- CircuPool RJ-60
Why did you add 70oz? You only needed 1/2 of that at the most. If you use the PoolMath app, it’ll help avoid making that mistake again as it calculates how much to add depending on the current level2:00 Today Test
CYA 40
ph 7.2
TA 120
Calcium 310
DPD -- Free Chlorine .4
Combined Chlorine .6
Put 70 oz of liquid chlorine in pool
7:00 p.m. went back to check #'s
Chlorine sky high
Couldn't get a number because I stopped adding drops after I added 80 and still sample was bright pink.
No change in water cloudiness.
Made the mistake of doing this the day before we are scheduled to work. Will have to go in early and try to neutralize the chlorine if it hasn't come down.
The DPD test doesn’t go above 10ppm. (Or 5ppm, I forget). If you get the FAS-DPD it reads a lot higher than you’ll ever need.
