- May 28, 2022
- 30
- Plaster
- CircuPool RJ-60
I slammed my pool two weeks ago after some minor algae flair-ups. Before slamming, I brushed the pool vigorously, vacuumed extensively, and cleaned my DE filter the following day. Two weeks later, the pool is crystal clear, and the FC and TC are 3.0 ppm and 0, respectively. However, my cyanuric acid is 75 ppm. I want to reduce that to the prescribed level of about 30 ppm. However, because I live in Southern California, and we are having a drought, I will drain the pool only as a last resort.
I read about the Bio Active brand cyanuric acid reduction treatment and decided to try it as an alternative to draining the water. I bought an 8 oz package on eBay ($28). Some have suggested it is more effective in warmer water, so I heated my pool from 71F to 82F before starting the treatment. A day after starting, the cyanuric acid is at 74 ppm. The package states it can take up to 10 days to realize the full results, but I'm becoming increasingly skeptical that this treatment will do much.
My question is, if this treatment is ineffective, how important is it to get the CYA levels down from the mid-70s?
BTW, my CYA increased gradually over the summer due to using Chlorine pucks in a floating dispenser. I did not realize until recently that the pucks included CYA, and have stopped using them.
