Hello,
I did read and I keep reading the Pool School articles, but I am still not sure what to do and how to do it. Probably will need some crash course for dummies
My results from last night:
FC 0.5
CC 2.5
TA 180
CYA probably 0 (filled the tube all the way up and the dot was still clearly visible)
pH 7.5
We put CYA pods in both skimmer baskets (from Walmart) and will repeat (I understand it takes about 13 pounds of Cyanuric to get CYA to 70)
Then I also need to lower TA. Muriatic acid and then aerating, right?
We do have slide (which could work as water feature, but how long do I need to aerate? And, can we go into pool when muriatic acid is added? My concern is that we normally keep the pool covered (and obviously can't aerate when covered), but I also don't want to keep it uncovered when no one is in because we have common grackle colony nesting around and still dive bombing our pool.
And then we also will need to SLAM to get the CC under 0.5.
Did I get it right? Do I need to adjust CYA first, then work on lowering TA and last to SLAM when CYA and TA are in desirable ranges?
AND, what about aerating during the TA lowering process?
Thanks in advance!
FC 0.5
CC 2.5
TA 180
pH 7.5
Thanks in advance!
