Hi,
I'm having trouble with CYA at a zero level after the winter. I've added 5# and still see little or no change. I first added 3# and could detect an increase in cloudiness in the test tube. Then I added 2# more and tested 3 weeks later and it's clear again. I can't find a record of measuring CYA since 2015 at which point it was 30ppm.
Last December the FC was at around 11ppm. At that point I turned the pumps off. This pool is covered almost all of the time, so I placed a cover pump on it for the winter. The pool remained undisturbed until the beginning of April. At that point the water was clear, the FC was 2-3ppm, pH=8.2. I turned on the system, added 3l of acid and by the beginning of May the FC was at 5.5ppm, CC=0, pH- 7.5-7.7, CH=475, TA=100, CYA = 0 (totally clear). Due to the heavy rains in Northern Cal this winter I had some dilution. The salt concentration went from 3700 to 3400ppm. When the pool was opened for the first few times this spring it had a slightly fishy smell.
I've never had a problem with cloudiness in my pool. I typically shoot for a FC of 3-4ppm, on the assumption I had a CYA of 30ppm.
Any idea why my CYA will not shift? The latest measurement of CYA=0 was with FC=9ppm, pH=7.6, temp around 79F.
Thanks
Chris
Thanks
Chris
