We have had our Strong spa since the end of April. It was set up by the company we purchased from. We have been using the chemicals they recommended including chlorine with dichlor in it. Consequently the CYA climbed to over 100ppms. Our tap water tested at less than 30ppms cya. We changed out over 80% of the water in the tub, (pool calculator said 75%) and the CYA is now at 50ppm. Our tap water tests at: FC 1.2, TC 0.2, PH 7.4, TA 150, CH 230, CYA <30. After the refill and time to reach 103 we test at: FC 0.4, TC 0.4, PH >8, TA 140, CH 200, CYA 50. I understand water temp and aeration play a roll in these factors. But I am confused why the PH went so high and the cya is that high after more water change than pool calculator recommended. We are changing out another 50% of the water to lower the cya. Any other suggestions? BTW- we are testing with Taylor k-2006c.
