History:
6/30 Store Results:
FC: .19 ppm
TC: 2.05
CC: 1.86
pH: 7.3
CH: 92
Alkalinity: 103
CYA: 2
7/2 SLAM (2 gallons of liquid stabilizer), 7/3 Results:
FC: 10.51 ppm
TC: 10.51
CC: 0
pH: 7
CH: 117
Alkalinity: 89
CYA: 35
7/5 Received the TF100 Kit and test the CYA level: Still see the black dot with the tube filled. Still SLAMMING around 15ppm FC. Added 1lbs of dry stabilizer using sock method.
7/6 AM: FC 13ppm, still SLAMMING and added 1 gallons to bring it to 19ppm to level with the dry stabilizer.
7/6: 3:30PM - did CYA test and still able to see the black dot. Is my test kit a dud? Should I take out the dry stabilizer or add more in? Pool is clearing up a bit but the deep-end is still cloudy. Been brushing and vacuuming 3x times today.
6/30 Store Results:
FC: .19 ppm
TC: 2.05
CC: 1.86
pH: 7.3
CH: 92
Alkalinity: 103
CYA: 2
FC: 10.51 ppm
TC: 10.51
CC: 0
pH: 7
CH: 117
Alkalinity: 89
CYA: 35
