I'm on the sixth day of being unable to clear my pool water. I'm trying to maintain my chlorine levels at shock level, however I'm having trouble figuring out how to get an accurate CYA reading. Instructions say that the CYA level is when the little dot at the bottom disappears. Problem seems to be that the water is so cloudy it's reading a much higher level than I think it really is. Not knowing how to check it otherwise, I went out and bought test strips which indicate my CYA is next to non-existent, which instinctively seems more correct based on just opening the pool and it being full of winter rain water.
So what am I missing with the CYA test? Won't the cloudy water cause the little dot to disappear--regardless of CYA or not? Without confidence in the CYA level, I'm not sure what level I'm seeking to shock it. Getting more than a little frustrated in trying to clear this up.
I'm 24 hours into my second treatment of clarifier. At this point I still see blue...I can see all three steps and can make out the light...but not even a hint of the drain at the 8 foot level.
Inground pool, 16x32, 3x by 8x, vinyl liner. PH seems to be 7.4...alkalinity is 90...CYA??? I'm not sure. Has cleared right up every other year...green cleared up by the next day, but I got to my current level of visibility in about three days, and I'm only marginally better...if any...three days later.
Any wisdom?
Any wisdom?
