Guys,
Quick CYA question - my understanding is that CYA doesn't go away and the only way to reduce it is to replace water in your pool. Based on that logic, I would assume the only thing that causes CYA to naturally drop over time is through usage of the pool (spillage/evaporation etc...).
So, am I right in thinking that once you've got your CYA level to where is needs to be, that's pretty much it? You check maybe every week (or once a month?) but it's not something you would typically check as regularly as PH and FC.
Is that right?
Bic
PS Also, am I right in thinking 30-50 would be a the target CYA range for my pool?
Is that right?
Bic
